Help
Hi hope someone can help.
I'm trying to replace the spark-plugs on my 2000 accord v6 and one of the ignition coil is stock won't come out. What can I do to remove it. Thanks |
If this is Coil-over-Plug, have you removed the bolt holding the COP down?
It may take a bit of force to separate the COP from the plug. good luck |
The coil head broke it was hard to remove the rest but I was able to do it. Thanks for your respond
I'd put a bit of dielectric grease there so it doesn't stick next time.
I will thanks for the info.
Oil Pressure light is on car wont start
update
i was able to replace the ignition coil. car was running fine until this morning, now the oil pressure light is on and car won't start, i check the oil level is fine, can anyone tell me what to look for any idea what is the problem. Thanks, |
Originally Posted by jron
(Post 310204)
update
Oil pressure light is usually a faulty oil pressure switch.
Regarding starting, do the Check Engine, Alt, Oil Pressure lights come on when keyswitch is turned to On? good luck |
(Post 310216)
I wasn't sure that oil pressure light and no-start were simultaneous events.
Yes, prolonged starting revs might cause oil pressure light to go off. Switch closes at only a few psi of pressure. I don't know this for certain. It may that in Start postion, oil light is held on? good luck |
