Help!!!!!!!!!!
I have an 04 accord and the ac stopped working the other day and I have done everything I know to do and still it still want come on at all and my power mirrors no longer work either.. I have done replaced all the relays and the blower motor resistor and checked all the fuses
Was there any work done on the car prior to this happening?
There is a common fuse in the under dash fuse box. It is #30 and is a 7.5 amp fuse. See pic below.
If the fuse keeps blowing, then you will have to determine what component is causing the fuse to blow. You would have to turn on one component at a time to see if it blows the fuse.
DO NOT use a fuse rated higher than 7.5 amps.
You didn't answer if there was any work done to the car prior to this happening.
Do you keep blowing that fuse?
Unplug that fuse. Use a volt meter to deterimne if you have voltage to one of the pins of that fuse socked. Use your red volt meter lead on the pin, and your black volt meter lead on a good ground. Key has to be in the II position for it to work.
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
