-   -   Help!!!!!!!!!! (https://www.hondaaccordforum.com/forum/general-tech-help-7/help-64796/)
mikecc Jul 16, 2017 10:37 AM
Help!!!!!!!!!!
I have an 04 accord and the ac stopped working the other day and I have done everything I know to do and still it still want come on at all and my power mirrors no longer work either.. I have done replaced all the relays and the blower motor resistor and checked all the fuses
PAhonda Jul 16, 2017 11:14 AM
How is the a/c not working? Does is blow warm air? Or is there no air (warm or cold) coming out of the vents?
Did the power mirrors stop working at the same time as the a/c?
mikecc Jul 16, 2017 11:35 AM
IT want do anything and yes the side mirrors quit the same time
PAhonda Jul 16, 2017 11:54 AM
Was there any work done on the car prior to this happening?
There is a common fuse in the under dash fuse box. It is #30 and is a 7.5 amp fuse. See pic below.
If the fuse keeps blowing, then you will have to determine what component is causing the fuse to blow. You would have to turn on one component at a time to see if it blows the fuse.
DO NOT use a fuse rated higher than 7.5 amps.
https://www.hondaaccordforum.com/for...fuses-8548.png
mikecc Jul 16, 2017 02:49 PM
yeah I have replaced that fuse and it still doesn't come on
PAhonda Jul 16, 2017 04:32 PM
You didn't answer if there was any work done to the car prior to this happening.
Do you keep blowing that fuse?
Unplug that fuse. Use a volt meter to deterimne if you have voltage to one of the pins of that fuse socked. Use your red volt meter lead on the pin, and your black volt meter lead on a good ground. Key has to be in the II position for it to work.
mikecc Jul 16, 2017 09:13 PM
no there has not been any work done prior to this happening but
TexasHonda Jul 17, 2017 10:04 AM
Time to check system pressure (static engine off). A pressure < 30 psi indicates low system charge (leak must be found).
