-   -   Help (https://www.hondaaccordforum.com/forum/general-tech-help-7/help-68491/)
dspeller May 14, 2021 02:52 PM
Help
What should I do if both tail lights won’t work but the brake lights do
Side Note- I went to change the tail light bulb but it didn’t need to be changed
shipo May 14, 2021 03:18 PM
Are there any other lights not working? If so, it sounds like a wiring harness issue. My (former) 2001 Accord had this issue, a squirrel decided the plastic in the wiring harness was tasty and chewed it up.
dspeller May 14, 2021 03:24 PM
Front head lights work & brake lights work
redbull-1 May 14, 2021 03:45 PM
Year, model, trim level would help.
FullCircleXpw May 15, 2021 02:37 AM
Not trying to be a contrarian but I would double check if its a double filament.
in any case if both sides stopped working at the same time I would start by verifying the it even works by applying power as close to the bulb in the circuit as you can. Then trace your way back to the switch checking for shorts or damaged/burned wire.
