help with 91 accord
Old Apr 17, 2006 | 11:16 PM
brownstreak's Avatar
Default help with 91 accord
I need to replace my hub assembly on both sides and the part that im stuck on is trying to get the rotor off the hub. what do I do??? do I need a special tool to pry it appart? Im stumped I dont want to try anything to forcefull yet untill I know I wont damage something..
thanks
Old Apr 17, 2006 | 11:54 PM
iridebmx33's Avatar
Default RE: help with 91 accord
Hello,
You need to get to the inside of your hub. Take the CV shaft out and on the back side of the hub there will be four bolts that need to come out. With those 4 bolts out the rotor should slide off with the outside 4 bolts off as well. I know this because I just changed my front rotors.
Good Luck!
Old Apr 18, 2006 | 07:39 PM
ok thanks
Old Apr 18, 2006 | 09:21 PM
deserthonda's Avatar
http://www.ozaccord.com/forums/showthread.php?t=41
this will guide you to replace the hub/ rotors/
why do you need to replace the hubs ??
Old Apr 19, 2006 | 10:02 PM
well correct me if im wrong but the bearing is one peice with the hub, and when I changed my drive axels the part where the spline goes in to the hub which I think is the bearing had alot of play in it. I tried to take it apart as much as I could so I could maybe see why it had play, but I just couldnt get it seperated to get in there. This is what I think my slight vibrating and grinding noise is. but please tell me what else it could be if it isn't what I think it is. also when i roll at a stop light I hear a clicking and high pitched scraping.
thanks for the link also.
Old Apr 20, 2006 | 01:18 PM
sir_nasty's Avatar
When you roll to a light you hear a clicking and scraping? Are your brakes okay? Did you do them recently and forget to put anti-squeel on there?
Old Apr 20, 2006 | 02:53 PM
yes actually I just did my brakes last week and I did put the anti sqeel on there so I know thats not the prob. also I forgot to mention when I had everything off I spun the rotor when it was all together and I felt a slight jerking as I spun it. so that just makes me think its the bearings.
Old Apr 24, 2006 | 05:42 PM
thanks for that guide deserthonda it came in handy..
Old Apr 24, 2006 | 06:47 PM
ORIGINAL: brownstreak
glad i could help make your job easier ,, that's why we are all here for..
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
