-   -   HELP A/C Control Does not work, changed fuses already (https://www.hondaaccordforum.com/forum/general-tech-help-7/help-c-control-does-not-work-changed-fuses-already-12707/)
Cun0144 Sep 22, 2007 03:35 PM
I have a 2000 honda accord EX. Just recently the Air Control/ AC control buttons on the dash would light on then off on and off as i was driving. My ac would go on and off on and off. The fan would still be running when it goes off. Anyways, now the button doesnt work anymore, u know the buttons that turns your defrost on/off a/c on/off air flow to your feet/body/ etc etc. Note that the 2 knobs work fine the ones that control the Fan speed 1/2/3/4, and the temperature knob. Ive tried changing the fuse for AC control and nothing. I took the whole dash out and looked at the wires, nothing appears to be grounding out or shorting. Any ideas? please help!!
nafango2 Sep 23, 2007 11:07 AM
RE: HELP A/C Control Does not work, changed fuses already
do the lights on the buttons light up or no?
Cun0144 Sep 23, 2007 12:19 PM
they light up, then it goes out 5-10 minute after i start driving and goes on and off randomly.
Cun0144 Sep 25, 2007 01:07 AM
nobody has any idea what the problem could be?!?!?:(
PAhonda Sep 25, 2007 02:32 AM
Hate to state the obvious, but it sounds like the mode control buttons are losing power or ground somehow.
I don't own a 6th gen. Is the A/C on/off button one of the buttons part of the mode control buttons? A better way to ask is, are all the switches that are having problems going through the same connector on the wire harness? Are other switches using different connectors working properly?
You might want to try putting dielectric grease on the faulty connector to ensure that you have a secure connection at the plug. There are continuity tests that you can do on the mode switch to see if it is working properly. You are going to have to get at the minimum a Haynes manual and a volt meter to run through the tests.
nafango2 Sep 30, 2007 08:33 PM
i think i remember reading a service bulletin about the A/C wires rubbing against each other constantly and eventually rubbing the insulation away and shorting them out. Check that, and if the car is still under the warranty take it into the dealer and make them fix it for free.
