Help Driver Side Door Jammed
Old Nov 12, 2006 | 07:37 PM
HondagalGA's Avatar
Default Help Driver Side Door Jammed
My driver side door will not open. Does anyone know anything about getting it unjammed? I tried unlocking and locking it back and it still will not open. Thanks in advance.
Old Nov 12, 2006 | 07:51 PM
HondagalGA's Avatar
Default RE: Help Driver Side Door Jammed
99 accord v6.
Old Nov 12, 2006 | 07:52 PM
YeuEmMaiMai's Avatar
gotta pull the door panel of and repair the locking mechanism does the lock work with the key?
Old Nov 12, 2006 | 07:55 PM
HondagalGA's Avatar
no, it will not open with the key. it will lock and unlock but not open. how much would this repair cost?
Old Nov 12, 2006 | 08:03 PM
if a dealer does it about 1 hour labor and parts
part#.pix#...description......color....list... www.hondaautomotiveparts.com price
27631 001 2 SWITCH ASSY., AUTO DOOR LOCK MILD BEIGE 14.40 10.80 Qty:
35581 001 2 SWITCH *NH264L* CLASSY GRAY 25.75 19.31 Qty:
35583 002 1 LOCK ASSY., R. FR. NO COLOR 107.43 80.57 Qty:
21427 003 1 SNAP (BROWN) NO COLOR 2.80 2.10 Qty:
21428 004 1 SNAP (BLACK) NO COLOR 1.10 0.82 Qty:
27635 005 1 ACTUATOR ASSY., R. FR. NO COLOR 40.35 30.26 Qty:
20761 006 1 HOLDER, L. ROD NO COLOR 3.30 2.48 Qty:
20762 007 1 HOLDER, R. ROD NO COLOR 2.20 1.65 Qty:
35585 008 1 PROTECTOR, R. FR. NO COLOR 1.23 0.92 Qty:
26990 009 2 SCREW, TAPPING (3X5) NO COLOR 1.42 1.06 Qty:
24313 010 4 STOPPER A, HANDLE (OUTER) NO COLOR 2.08 1.56 Qty:
21436 011 2 RING, HANDLE (OUTER) NO COLOR 1.78 1.34 Qty:
35586 012 1 CASE, R. *NH264L* CLASSY GRAY 28.88 21.66 Qty:
35588 012 1 CASE, R. *YR169L* MILD BEIGE 28.88 21.66 Qty:
35589 013 2 CAP, CASE *NH264L* CLASSY GRAY 1.87 1.40 Qty:
27641 013 2 CAP, CASE MILD BEIGE 1.97 1.48 Qty:
35590 014 1 PROTECTOR, R. FR. NO COLOR 4.72 3.54 Qty:
35591 015 1 ROD, R. FR. NO COLOR 1.77 1.33 Qty:
21443 016 2 BUSH, HANDLE JOINT (OUTER) NO COLOR 1.48 1.11 Qty:
21444 017 2 STRIKER ASSY., DOOR LOCK NO COLOR 15.52 11.64 Qty:
30274 018 2 **** *NH264L* CLASSY GRAY 4.72 3.54 Qty:
35592 018 2 **** *YR169L* MILD BEIGE 5.23 3.92 Qty:
21445 019 1 SNAP (VIOLET) NO COLOR 4.40 3.30 Qty:
24321 020 2 TUBE, FR. NO COLOR 3.87 2.90 Qty:
35595 021 1 HANDLE, R. *G87P* DARK EMERALD PEARL 54.85 41.14 Qty:
35596 021 1 HANDLE, R. *NH578* TAFFETA WHITE 54.85 41.14 Qty:
35597 021 1 HANDLE, R. *NH592P* FLAMENCO BLACK PEARL 52.43 39.32 Qty:
35600 021 1 HANDLE, R. FR. *R94* SAN MARINO RED 54.85 41.14 Qty:
35602 021 1 HANDLE, R. *NH623M* SATIN SILVER METALLIC 54.85 41.14 Qty:
35603 022 1 SWITCH ASSY., R. NO COLOR 12.82 9.62 Qty:
35604 023 1 CYLINDER, R. DOOR NO COLOR 53.58 40.19 Qty:
35605 024 1 LOCK ASSY., L. FR. NO COLOR 88.03 66.02 Qty:
27662 025 1 ACTUATOR ASSY., L. FR. DOOR LOCK NO COLOR 34.78 26.09 Qty:
35606 026 1 PROTECTOR, L. FR. NO COLOR 1.95 1.46 Qty:
35607 027 1 CASE, L. *NH264L* CLASSY GRAY 28.88 21.66 Qty:
35609 027 1 CASE, L. *YR169L* MILD BEIGE 28.88 21.66 Qty:
35610 028 1 PROTECTOR, L. FR. NO COLOR 4.72 3.54 Qty:
35611 029 1 ROD, L. FR. NO COLOR 1.77 1.33 Qty:
23681 030 4 HOLDER, DOOR LOCK ROD NO COLOR 0.33 0.25 Qty:
35613 031 1 HANDLE, L. *G87P* DARK EMERALD PEARL 54.85 41.14 Qty:
35614 031 1 HANDLE, L. *NH578* TAFFETA WHITE 54.85 41.14 Qty:
35615 031 1 HANDLE, L. *NH592P* FLAMENCO BLACK PEARL 52.43 39.32 Qty:
35618 031 1 HANDLE, L. FR. *R94* SAN MARINO RED 54.85 41.14 Qty:
35620 031 1 HANDLE, L. *NH623M* SATIN SILVER METALLIC 54.85 41.14 Qty:
35622 032 1 SWITCH ASSY., L. NO COLOR 21.50 16.13 Qty:
35624 033 1 CYLINDER, L. DOOR NO COLOR 54.42 40.81 Qty:
21488 034 1 SNAP (NATURAL) NO COLOR 1.78 1.34 Qty:
27678 035 1 SNAP, R. NO COLOR 1.58 1.19 Qty:
27680 036 1 SNAP, L. NO COLOR 1.58 1.19 Qty:
5249 037 2 JOINT NO COLOR 3.43 2.57 Qty:
21490 038 2 SCREW, TAPPING NO COLOR 1.25 0.94 Qty:
21491 039 4 BOLT, DOOR LOCK STRIKER NO COLOR 1.73 1.30 Qty:
27681 040 4 SCREW (3X10) NO COLOR 0.55 0.41 Qty:
24364 041 2 GROMMET, SCREW (4MM) NO COLOR 3.28 2.46 Qty:
20015 042 6 CLIP, HARNESS BAND (151.5MM) (NATURAL) NO COLOR 1.07 0.80 Qty:
1305 043 4 BOLT-WASHER (6X12) NO COLOR 0.80 0.60 Qty:
21492 044 6 SCREW, FLAT (6X28) NO COLOR 0.55 0.41 Qty:
21493 045 2 SCREW, TAPPING (3X8) NO COLOR 3.60 2.70 Qty:
22303 046 4 SCREW, TAPPING (3X12) NO COLOR 0.40 0.30 Qty:
Old Nov 12, 2006 | 08:08 PM
HondagalGA's Avatar
recomend a honda dealer does it? or is it something that you could do on your own or a lock smith place?
Old Nov 13, 2006 | 03:04 AM
HondagalGA's Avatar
How do i remove the door panel?
Old Nov 13, 2006 | 09:38 AM
there are usually 3 secrews in the arm rest and interior opener and then you pry off the panel carefully trying not to break any of the clips
Old Nov 13, 2006 | 12:32 PM
ohccord's Avatar
If it's anything like the earlier 90's, good luck. Honda built in some safety latch and when it fails to work you can not get at it to release. At least I haven't found away.
The previous only destroyed the door attempted to pry the door open rendering the door useless. I could figure out how to release the latch, so I had to cut the door skin and door brace to get this side of the latch and release it. There was no way to get at it.
I modified the replacement doors latch mechanism, so it wouldn't jam.
Old Nov 13, 2006 | 01:30 PM
HondagalGA's Avatar
Thanks will give it a try.com
