-   -   Help! I need answers!! (https://www.hondaaccordforum.com/forum/general-tech-help-7/help-i-need-answers-54865/)
CMR May 17, 2013 10:51 PM
I have 94 Honda Accord LX coupe and today my windows would not roll up or down neither would any of my indicator lights come on, as well as the car wouldn't shift gears. It cranks up fine but doesn't shift gears. Has anyone ever had this issue or have an idea what it could be?
TexasHonda May 18, 2013 08:03 AM
Windows. Have you checked that interior lock switch is Off? Otherwise, check fuses in underhood fuse/relay box (fuses 15, 24, 25, 26, 28).
Shift Lock - First thing to check is whether your brake lights working? If brake lights are not coming on, the brake light switch may be stuck closed. Sometimes a good dose of WD40 will restore operation. Or, the rubber grommet which depresses the switch may have rotted and fallen out. Get a replacement plastic grommet from Honda.
