HELP!! need to find out the name of this part!
2 Attachment(s)
This part started squirt hot radiant fluid all over my engine this morining. I went to the dealership and they printed out a blueprint but that part did not have a name nor a part number. Please Help!! Im attaching two photo so hopefully you can diagnosis the part.:eek:
What year/model accord do you have?
Sergio...please put in that information in the bottom box better know as the signature box...:)
I'm guessing it's a 96 EX
That part is called a breather pipe, it has a coolant transfer tube joined to it. I'm pretty sure the part is called out in the "Breather Tube" parts page., or it is in hondanet parts listings. try this link; http://www.hondaautomotiveparts.com/home.htm |
Hi Guys
1 Attachment(s)
That's what All Data DIY is calling it also...:)
Two metal tubes stuck to each other side-by-side. One carries air for the crankcase vent system. The other tube carries coolant, just to keep the air-tube warm.
Is the steel tube cracked? Or did the rubber hose broke open? Busted hose clamp allowed the hose to be disconnected? http://www.hondaautomotiveparts.com/...13SV40_E08.gif |
| All times are GMT -5. The time now is 05:21 AM. |
