Help needed
Anybody know how to reset 05 accord coupe air bag light? It has never been deployed and disconnecting battery didn't work
On older accords, it was simple to reset the SRS light. On newer accords, you may have to take it to the dealership.
The SRS turning on means that the SRS control unit detected a problem. It may be that something is wrong with a component in the airbag system. |
how much will the dealer usually charge??
I have no idea. You will have to call and get a quote.
You might find an independent shop that specializes in hondas and/or foreign cars that would have the scanner to do it as well. |
2 recalls apply to your car, and many restraint system parts are covered under warranty.
If you go to the dealership the first thing you want is a "VIN STATUS INQUIRY" run on your car by the service dept. Safety Recall: Driver's Seat Position Sensor Harness Replacement January 20, 2007 Safety Recall: Driver’s Airbag March 1, 2005 |
| All times are GMT -5. The time now is 10:31 AM. |
