HIDs working DRL not?
I have a 2011 Honda accord coupe V6. Today I installed 6000k Hid(ballast and cancler combo) lights on my car. As soon as I plugged them in and ran a test I realized that my HIDs worked however my DRLs no
https://www.hondaaccordforum.com/for...l-about-26638/ *** longer came on, yet my high beams (same bulb) still worked. I then replaced all the factory bulbs and they still would not come on. I checked the DRL fuse, and it was still intact. I have HIDs installed now, and my DRLs dont seem to work. Is it possible to have both DRL's and HIDs installed and working in your car and is there a way to fix my problem? Also note I never disconnected my DRL bulbs. Could this be because I didn't use a relay for my HIDs? |
It's most likely due to a fuse, there is more one fuse in the circuit. The Accord uses the halogen high beams with a reduced brightness for DRL. The DRL system includes the driver’s multiplex integrated control unit (MICU), the passenger MICU, the left and right high beam headlights, and the DRL indicator.
Check both the No. 15 and No. 28 fuses in the driver's side under-dash fuse box and No.1 fuse in the passenger’s under-dash fuse/relay box |
| All times are GMT -5. The time now is 12:47 AM. |
