High Output Alt Belt 2013
I apologize as I did do a quick search and may have overlooked the answer. The post topic is pretty much my question...what belt did you guys end up going with? Are there any stock belts from other cars that fit or am I forced to pay 70-120 for a custom fit? 2013 Accord EX-L 4cyl, 300amp AutoTech Alt
If the pulley is the same diameter on the new alternator, then you can use the same size belt.
If it is larger, then you can try to calculate the difference in length needed. There may be some online calculators for the belt size needed. You can do some geometry to estimate the belt size. |
| All times are GMT -5. The time now is 11:04 PM. |
