Highlights which is high beam
I bought a used 2007 Honda Accord but the headlights seem to be wrong and wondering if the previous owner put low beam lights in high beam sockets or vice a versa. the car takes 4 bulbs and want to make sure the low beam bulbs go in the correct position and High beam bulbs go in the high beam sockets
Question: So does anyone know which sockets are which? |
Do you have a picture? My 07 Accord isn't home right now so I can't go outside and look.....it should be home sometime today so I can go look at it later if someone else doesn't chime in before then :)
Upper bulb (60w) is high beam and lower bulb (51w) low beam.
good luck |
The bulbs should have 2 wires, where one wire is black on all of them.
The other wire color for each bulb is listed below. Driver's high - wht/yel Driver's low - red/yel Passenger's high - wht/grn Passenger's low - red/grn Either the bulbs or the connectors are switched. Here is a video on how to change the high bulb to show the location. |
| All times are GMT -5. The time now is 08:14 AM. |
