Honda Accord 2000 - Engine Code P1739
Hi,
I went to buy a used car from a private seller today and when I got the engine checked, there was a code P1739 displayed. The car has 141k miles on it and is a Honda Accord 2000. I am getting it at a decent price so I told them I would think about taking it if they can get that fixed (the car has a transmission warranty of 7 years or 100k miles that they obtained when the car had 82k miles on it). They agreed to it and we are going to the dealer together. I am not understanding if this is a minor problem that can be fixed or a major problem that is warning me to stay away from this car. The car looks well maintained and the oil was changed regularly every 3 months so the general maintenance looks good to me but I might be wrong. Can someone advice me on this please? |
That code is for the 3rd clutch switch.
The 6th generation accords (98-02) have had a lot of transmissions fail due a design flaw. I think that a bearing in there would break apart and clog the fluid passages. From a quick search, this P1739 might be a sign that the transmission is failing. The warranty will expire in 40K miles, so keep that in mind. If the dealership agrees to replace the transmission with a rebuilt one, then that will help. See if they will warranty the replacement transmission. |
best advice i can give you...........spend 70-80 dollars and have the car inspected by a shop that specializes on Hondas or a Honda dealer ,, and tell them about the chk engine lite being on.ask them to do a buyer's inspection
P1739 is a transmission code ,,,,I would not buy the car till you know for sure what the issue is ..About the tranny having a 7 yrs or 100k miles warranty ,, did you actually see the warranty paper and the name of the shop that performed the job??? |
Are you sure that the warranty isn't 7years/100K from original purchase date. That would mean that the warranty ran out sometime around 2007. Those accords had a warranty extension (trans only) on them until 105K miles and 7 years 9months from original purchase date. Even with honda certified cars it is always from the original "in service" which starts the day the car is originally sold.
@deserthonda:
I saw the warranty papers. The place is called: Windy City Honda located at S. Pulaski Road in Chicago. It says that the tranny was replaced when the car had 81k miles on it. And then it had a note saying: "7 years or 100k miles". So I thought it was a warranty from the date of replacement. Thank You for that.. So I will do the following in that case: 1. Take it to Pepboys to get a buyer's inspection 2. Check with the dealer if the warranty covers even now or if it has already expired. 3. Ask for a transmission replacement and verify if the dealer would give another warranty. Thanks again... at least now I won't take any hasty step... Added that that, I am taking the owner to the dealer as well, so if they say there is no more warranty I will ask the owner to replace it (which I highly doubt that he will...) or I'll pass the deal. Here's a carfax report that made me think it was a great car: Code:
03/28/2003 27,303 Illinois Motor Vehicle Dept. |
I have been to honda dealer, I was given two more codes 91737 and p0700 which i was told that they are also simalar to p1739. he told me the transmiiion is good, however third switch has to be chngd, that it would cost me abt $250 to get it done, rigt now i am getting buyers inspection done at pepboys, as there are no major problems i am not sure how long the car would survive. Dealers say car is fine but i am not sure about it please advice me in this regard.
I don't know those specific codes for the 2000, but it sounds like the transmission is on its way out.
Unless Honda will replace the transmission under the previous warranty, then I would not buy this car. |
i agree with PA.........make extra sure that tranny will be covered under warranty should something happen
