Honda Accord 2002 EX Tail light replacing?
Old Mar 10, 2009 | 11:22 AM
freeforfrank
Default Honda Accord 2002 EX Tail light replacing?
I broke the tail light cover on the right side. How do I replace it? Can I replace the cover only? or I have to change the whole assembly? Anybody can help to give me a diy instruction?
Old Mar 10, 2009 | 11:32 AM
finch13's Avatar
Cover? As in the red/clear/orange lens?
You'll need to search a local junkyard or buy a set online. There's 4-5 studs going through the trunk and bolts holding them on. Simple unplug all the bulbs, remove the bolts and pull the light away.
Old Mar 10, 2009 | 11:46 AM
Vipers4Life's Avatar
You don't have to change the whole set for the lights to work. As long as the bulbs are in the right spots than it should be fine. If one bulb or bulb holder socket is not connected or missing then none of the tail lights will light up.
Old Mar 10, 2009 | 12:21 PM
finch13's Avatar
No, you don't have to buy a whole set. But, if you can't find an OEM one at the yard, you're better off buying a whole set of new ones because the colors won't match to the old and new lights.
Our sponsor, http://www.tasauto.com, has replacement lights ins tock and they fast and reliable. Usually, I wouldn't point you in the direction of a sponsor, but their service and parts are top notch and I buy from them all the time
Old Mar 10, 2009 | 01:16 PM
freeforfrank
Thanks for the replies. The tail lights work fine. Just the plastic cover was cracked. So I can just find that cover piece in the junkyard? I don't even know where to find a junkyard locally. How much do they usually want for that? I also find the key hole to the trunk runs through that cover, will that make the installation more difficult?
kevinyu1115
Apr 17, 2025 01:21 AM
dgoldb1
Jan 18, 2014 07:59 PM
Lilmet12
Sep 29, 2012 10:36 AM
Dieselpro
May 19, 2011 09:23 PM
whit
Mar 10, 2009 10:48 AM
