Honda Accord 2013, 2.0 D headlight
Hi, I am looking for some advice regarding my headlight on my Honda Accord. I notice the right headlight low beam and high beam did not work sufficiently. Once I start car, there is low light in the beginning before it becomes all dark. The right side low head and high is not working at all after some minutes.
I tried to locate the bulb for replacing, but can not find it. Does that mean this is led type. I find all the other bulbs but not the one for the headlight. I did check the fuses, but they all seem ok. Could it be a relay that is causing this or is it the led light itself. Anyone have any recommendations for me I would appreciate it very much. It says also in the manual that if the low headlight are LED type, one should have a authorized Honda dealer to inspect and replace the light bulbs. Would that be neccessary, or is it something normal people can do? Thanks in advance for any help. |
I remember reading the LED headlights on your accord has a 10 year warranty, so the dealership may be able to replace them. It is worth a call.
Hi, will try that. Thanks for the tip!
But if not, any idea where to get new and ho to replace? |
I think the LED is part of the headlight assembly, so I don't think you can easily replace the bulb. There may be a writeup or youtube video on how to separate the lens cover, then replace the LED strip for your accord.
