Honda Accord 205 v6 stoped running
I was on highway fast lane and my car stopped getting speed and stayed slowing down then turned off and would not start had to get it towed and when got it to House it turned on for a few seconds dis anyone have any ideas that could be wrong with it
A lot of items can cause the car to stall out, so you have to diagnose the problem. If you can scan for codes, that may help guide you to test an electronic component.
Losing spark, fuel, or timing can cause the engine to not start. Start with the simple stuff first. Is your gas tank empty? Can you hear the fuel pump turn on when you turn the key to the II position, but do not try to start the car? The pump will turn on for about 2 seconds usually when the check engine light turns on for 2 seconds and make a faint buzzing/whirling sound from the back seat. |
Originally Posted by Macc992
(Post 377580)
Thank you I appreciate the response
