HONDA ACCORD ES 2.0i ENG MANAGEMENT ECM PLUG CONNECTOR
I have vtec 1999, eng man light on, have located the ECM but can not locate the plug connector to by pass to read the fault code. Where can I find this info or IF somebody can tell me where it is please.
Thanks. Park. |
RE: HONDA ACCORD ES 2.0i ENG MANAGEMENT ECM PLUG CONNECTOR
I have found ECM under the glove compt somewher rather in the centre BUT no BLUE PLUG in visible. LOOKED under dash board but no luck. WAITING FOR UR REPLY.
you'll need to have the codes read with a scan tool to get an accurate reading, the DLC connector should be just above the drivers side kick panel
is it the chk engine lite or the maintanace lite ???
if it is the chk engine lite do as the DUDE said,,,, go to Autozone , they will chk it at no cost , |
1999. Took it to Honda, very Low oil level code !! They reset it charged me £40.
The plug was 16 pin not 2 pin I was told. Thanks all. |
for future codes I'd find a shop/parts store in the area that will do free code reads, there should be someone who will do it without charging you just to read a code....
