Sponsored by:
Sponsored by:
2007 Accord Won't Start
Old 01-12-2014, 08:47 AM
NDT700's Avatar
Default 2007 Accord Won't Start
Removed battery to change low beam head lights. Car will not start now. Need help as i dont unstand what could have happened.
Old 01-12-2014, 08:50 AM
NDT700's Avatar
Default 2007 Accord wont start
Old 01-12-2014, 09:54 AM
This will get confusing...I've merged the two threads together and moved it to General Tech - better place than the new member area....BTW, welcome to HAF.
What is the starter doing? Is the starter spinning the engine, or when you turn the key to start - nothing happens?
Old 01-12-2014, 10:41 AM
NDT700's Avatar
It is turning over, but still wont start. It was running before i removed the battery. I do have an auto starter (Viper) on the car and dont know if that will stop it from starting.
Old 01-12-2014, 11:05 AM
Yea, if you have a remote or alarm I would try re-setting them as they might have "tripped" when removing or re-connecting the battery.
When you turn the key to the "on" position, do you hear the fuel pump prime for ~3 seconds?
Old 01-12-2014, 11:30 AM
NDT700's Avatar
I will check after work today. Thanks
Old 01-12-2014, 12:58 PM
Check the battery connections again. Disconnect and reinstall them to see if it makes a difference.
If it still doesn't start, pay attention to what the instrument panel Immobilizer indicator does when you turn the ignition with the key; and report back what it shows.
Old 01-15-2014, 04:37 PM
NDT700's Avatar
Found the battery to have dead cell and reprogramed the auto start. Thank you to all that helped me out.
radtodd1
10-11-2021 07:49 AM
Sheri6889
06-17-2015 08:19 AM
Moneymanminn1
02-01-2013 05:49 PM
Lunalobowolf
10-26-2012 09:33 PM
brs7024
12-01-2011 05:20 AM
Quick Reply: 2007 Accord Won't Start
