horn and cruise issues
I have an 08 Accord. My cruise control and horn has stopped working. I have check the fuse and it is good. My steering wheel radio controls also work. Any clue?
Was there anything done or happened before both stopped working?
The horn switch and cruise control combination switch both run through the cable reel to supply the ground to their respective circuits. If the ground is not being sent, issue may possibly be due to a faulty cruise control combination switch or cable reel. However, circuit will subsequently also go through other wiring, etc. too. Note: the horn switch circuit runs through the cruise control switch before preceding further through the cable reel. |
