Hose near Radiator
I brought a 94 honda in May haven't had any problem with until now.. I got basically because I want that model to fix up.... Well I replace the The rubber disk (part of the cap) on the side of the radiator it been working fine until last night I noticed fluids coming from that area I orignally tried finding something to close the area off so it would leak so I place a pencil because I cannot find what to seal it with it work fine until NOW... I need help any suggestions
If you mean the drain valve is leaking, only fix is a new rubber sealing washer or new plug/washer combination. If you can't seal w/ a new plug/washer you may need to replace the radiator. Following is link to a plug on Amazon. Yours may be different.
http://www.amazon.com/TER-Radiator-D.../dp/B001G5Y6W6
jamesejam
Sep 21, 2009 02:37 PM
