how to check CELs
I have a h22a4 in my 97 accord running a OBD1 Phearable.net ECU. I was wondering if someone could tell me how to check the CELs
thanks |
RE: how to check CELs
as long as you reconnected all the wiring you should still have the blue connector under the passenger side dash just like any other obd1
ORIGINAL: sir_nasty as long as you reconnected all the wiring you should still have the blue connector under the passenger side dash just like any other obd1 |
got it to work, thanks sir nasty, I got the tps sensor one and the vtec oil pressure switch one, that would explain why vtec isnt working
| All times are GMT -5. The time now is 03:45 AM. |
