How do I access the parking brake switch (2001 Accord)
1 Attachment(s)
delete
Lift up on the trim around the shifter and it will pop out. Just rotate it out of the way and the parking brake switch is there on the e-brake with a green or black wire coming from it.
I don't know if you can get away without removing the WHOLE console. Good luck.
Probably have to remove the shift handle & boot? The cupholder #7 snaps out by pulling upwards. The next piece #13 also snaps out but I always had trouble grabbing it. http://www.hondaautomotiveparts.com/...S840_B3740.gif If you can't reach the wire now, you have to remove the console #14. Center bin #11 has to come out, but not easy to grab. I think there's a panel above #11 that has to come out first?? Remove the dashboard side panels to expose the screws #43. Remove the "floor" of the storage bin #18 to expose a couple more screws. (I hope I haven't forgotten much...) |
delete
I'm not sure which side screws you mean, but I've had the console out ('98) without removing the seats.
