How do I make my brake light more sensitive?
Hi there....
when i press down on the brake.. the light are not that sensitive to light up.. I have to press all the way down for it to go on. since changing the brakes and rotor..this happen. usually it will light up when i applied the brake half way.. but now it have to go all the way down....... is there a setting for this??? thank you..... |
RE: How do I make my brake light more sensitive?
The lights are controlled by a little switch up above the pivot of the brake pedal. You'll have to stick your head down at the floor & maybe(?) push some trim peices out of the way.
Sounds like that switch is out-of-position, or screwed up, or maybe it's bracket is bent. Have to get down there & look at it to see what's up. |
where does the switch located it?
on front brake??? pax or driver side??? |
ORIGINAL: kennilope where does the switch located it? on front brake??? pax or driver side??? |
OK.. sorry for that stupid question.
i just realized i read it wrong.. and as i read the reply i had a good laugh at myself for how stupid i have been asking that dumb question I though he say the switch is in the brake pad somewhere in there... LMAO..... i need some drugs...https://www.hondaaccordforum.com/micons/m16.gif |
the greatest thing in life is a good laugh.....
I m glad you had one..... |
