How do I route speaker wire through the door
1 Attachment(s)
I want to run some speaker wire from my amp to my doors. I want to run them through the weather protecting cover that wires are already running through. (see attached).
Attachment 4790 Any idea how to access these on the driver and passenger side? |
just use the factory wires.
Much much much easier and can handle whatever power you have, I know for a fact. |
Thanks for the reply crispin.
I guess i should have added that ive already done that with some speakers that i have. They blew out so im replaceing them with some higher end speakers that can handle my amp... The reason that i want to run these wires through the door is that i want to have a direct connection from the amp to the crossover that comes with the speakers. I read somewhere that the more "breaks" that a wire has the less reliable the wire. If I go through the factory wires from amp to speakers will have 2 breaks, but if i go directly to the crossover amp to speakers will only be 1 break... Any ideas? |
| All times are GMT -5. The time now is 08:07 AM. |
