Sponsored by:
Sponsored by:
Check engine light and transmission question
Old 08-25-2011, 11:22 PM
josil20's Avatar
Default Check engine light and transmission question
Hello guys,
First time poster...reader for couple of months. Thanks everyone.
I recently bought a 2000 Accord LX Automatic. I have three issues with the car
1. I think the check engine light is out. When I insert the key in and before I crank the engine, all lights (like oil pressure, brake etc) come on. But the check engine light doesn't come on. Any thoughts?
2. Transmission - it feels that the transmission is hold longer in the first gear. RPM goes up to 3.5 before it switches to second. 2 to 3 and 3 to 4 are smooth. Any thoughts?
3. In most cars, once the car is running for 10-15 mins, the temperature gauge is exactly in the middle. But in my car it is slightly below the middle. Is this an issue?
Thanks
Old 08-25-2011, 11:36 PM
1. The check engine light should turn on for about two seconds for a bulb check when you turn the key to the II position before you start the car. If the bulb isn't turning on, then you may have a bulb burned out. Someone could have put some electrical tape to hide the fact the car has a check engine light turned on.
2. I never owned an automatic accord, so I don't know how it should shift.
3. The temperature gauge at normal running temperature is about 1/4 or 1/3 up on the scale, so yours sounds normal.
Old 08-26-2011, 12:07 AM
josil20's Avatar
Thanks for your quick reply.
I will replace the bulb and see.
Old 08-26-2011, 06:24 PM
Since you just got the car, I'd set a baseline on the trans fluid. Which means, do two to three drain and fills (drive a few miles in between) with Honda fluid.
Old 08-27-2011, 12:12 AM
piggylover1985's Avatar
If it's not slipping then you're good to go. Honda Odyssey shift out of 1st @3500 rpm is normal.
r1balla
06-29-2010 10:32 PM
ddold@gkschools.org
01-29-2008 03:35 PM
accordEX98
08-20-2007 03:43 PM
Quick Reply: Check engine light and transmission question
