-   -   how to install rear brake pads on 94 accord ? (https://www.hondaaccordforum.com/forum/general-tech-help-7/how-install-rear-brake-pads-94-accord-48883/)
bigwater Jul 15, 2012 12:40 PM
i have just replaced the front pads but having trouble replacing the pads on the rear . i used a c clamp on the front to get the cylinder back in on the caliber but this wont work on the rear .. how do i go about it on the rear ?
poorman212 Jul 15, 2012 12:45 PM
Moved to the proper section, please read the "stickies" at the top of the sections.
The rear calipers on this gen "screw" in. PLEASE do not use a c-clamp on them as damage can/will be done. There are several ways of doing this....but in the end the piston screws back into the caliper.
bigwater Jul 15, 2012 12:53 PM
how do i go about getting the piston back in so i have clearence to get caliber back on over new pads ?
poorman212 Jul 15, 2012 01:05 PM
It "screws" in. The piston has a cross "+" in it. You need something (there are special tools, some use other methods) to screw the piston back into the caliper.
bigwater Jul 15, 2012 01:17 PM
do i have to open the bleeder on the brakes to get it to screw back in ?
poorman212 Jul 15, 2012 01:32 PM
1 Attachment(s)
I don't ? I have a tool I put on the end of a 3/8 extention that "mates" to the cross in the piston and just screw it back in.........
Some will/have used a BIG flat head screw driver or pry bar blade to screw it in.....think of it as a "phillips" screw that needs to be screwed in.
Clockwise to screw it in....
bigwater Jul 15, 2012 01:35 PM
thanks a lot .
TexasHonda Jul 15, 2012 01:36 PM
Many part stores have a brake tools kit that has a tool for this. I've used a wood chisel, but the first rotation can be very difficult.
poorman212 Jul 15, 2012 01:57 PM
Originally Posted by bigwater (Post 289303)
thanks a lot .
Anytime :)
Let us know how it goes. Note the part in the attachment where you want the grove in the piston and the "nubs" on the backing plate of the pads to line up.
JimBlake Jul 16, 2012 12:55 PM
Finally, if you really worked at it with a C-clamp (before getting our advice), you may have damaged the handbrake auto-adjust mechanism. Then the proper method might not work any more.
