how to remove a 3m double-sided tape?
I bought an aftermarket fuel lid cover on my 09 accord. unfortunately I didnt put it right, I want to redo it again. I tried to remove it but it was so sticky. my questions are:
what tool do I need to use to remove it? If I removed it already can I buy another 3m tap so I can stick it back again to the fuel lid? pardon my english. this is also my first post. thanks in advance |
sorry I put this in the wrong forum. Idk how to move this to the general discussion forum
Moved it for you..Welcome!
Adhesive remover from auto stores or Walmart should work.
Goof Off adhesive remover works very well.
I like 3M adhesive remover which I was able to pick up at Walmart. It is in the auto section and can have a black or white label. The one I bought was a white label.
walmart.com/ip/3M-12-oz-Adhesive-Remover/17056835 |
Then for new tape, 3m would be the brand of tape I would look for....you'll have to figure out width and thickness. Then go to a good parts store or if there is a paint store near by then go there, they should have or be able to get you what you will need.
thanks a lot I appreciate it
