ecm code
Old 01-22-2011, 09:00 PM
wknox's Avatar
Default ecm code
Just picked up an 87 Accord, 97000 miles, the PCM flashes on just after you start to drive. I checked the code. It flashed 12 times consecutive, no long flash then short flashed, just 12 flashes.
I pulled the fuse to ecu and cleared the code
thanks
willie
87 Accord LXi, auto
91 Previa LE
96 Impala SS
Old 01-23-2011, 07:52 AM
Code 12? Was this from the dash or the ecm under the drivers seat. I ask becuase I don't see a code 12 listed for this generation..
Old 01-23-2011, 09:51 AM
If you don't have a manual download the "86-89 Accord Secan" manual from Online Manuals link in DIY forum. Secan is misspelled sedan.
Review how to read codes and read your codes again when/if codes reappear. You may have two codes adding up to 12 (5+7), if you missed a long pause. Manual shows no code 12 as pointed out.
Fomoco1
11-21-2012 01:56 PM
wattsk69
05-10-2012 11:56 AM
bastian
05-09-2010 04:47 PM
94vteccoupe
11-06-2006 07:02 PM
Parkavenue
09-18-2006 06:59 PM
Quick Reply: ecm code
