how to replace a bulb under the dash?
It looks like a bulb under my speedometer is out. The manual doesn't mention anything about changing a bulb under the dash. Does anyone have any experience or can point me in the right direction about how to replace a bulb under the dash?
Thank you! |
RE: how to replace a bulb under the dash?
it might require to remove the instrument cluster ,, but first things first ..which bulb is it exactly ??
why don't you input the year and model in your signature so we all know what you need help on. .and give us a bit more details |
Sorry about that...2000 Honda Accord 2-dr EX.
Its the higher RPM numbers and the lower speeds on the speedometerthat are dim as if a bulb is burnt out. |
I believe in our DIY section is a writeup in instrument guage cluster replacement. I'd look through that and it should show you how to remove it and then you just need to replace the bulb
I searched for "instrument gauge" and "instrument cluster" in the DIY Section and got zero results.
it was called dashboard guages *L* sorry about that but here it is
https://www.hondaaccordforum.com/DIY...m_25695/tm.htm |
Thanks! That is definitely good information! Now I know how to get out the dashboard section.
The link also says: "The 7th Gen Accord has LED soldered to the circuit and its hard to change the bulbs." Do you know if that's the same scenario for 6th generation Accords? I searched the forums but didn't get any results regarding how the bulbs are attached to the circuit board. Do you know how the bulbs are attached to the circuit board? |
| All times are GMT -5. The time now is 08:18 AM. |
