IAT sensor throwing code [since new CAI]?
I recently installed a cold air intake on my 1998 3.0 Accord coupe. After 500 miles, it threw a code. I looked it up, a P01112 IAT sensor; which would make sense because it's cold air intake. I go to school at Wyotech and other students with CB8's don't have this problem.
Should I replace the sensor or is there an aftermarket IAT that I can buy that would solve this problem? |
You should test the resistance across the sensor. It should be between 0.4 and 4 Kohms.
Also test to see if you have ~5V to one of the two wires of the electrical connector when the key is in the II position. |
reply
hey thanks for all your help i apreciate it man
| All times are GMT -5. The time now is 07:42 AM. |
