Idiot Light 'Check Engine Light' [Code:P1456]
Old Mar 14, 2016 | 10:29 PM
With any code, there is a sensor that is reporting a number to the computer that is out of the normal range. In the case of P1456, it is a pressure sensor.
Now the problem could be the sensor is reading properly and you have a leak in the tank side of the EVAP system, or your sensor is not working properly. This is where you have to do some diagnostic work to find the problem.
Has any work been done your car recently?
Old Mar 14, 2016 | 10:49 PM
Ttripp's Avatar
Did a tuneup, changed all brake pads . Had tensioner pulley replaced 3 mos ago. That's all the most recent work done
Old Mar 15, 2016 | 08:01 AM
Even without having any work done under the car, those rubber vacuum hoses are still about 17 years old. Make sure they aren't getting brittle & cracking.
Old Mar 15, 2016 | 11:01 AM
Attached is some more info. to add to what was previously posted in this thread.
Attached Thumbnails  Idiot Light 'Check Engine Light' [Code:P1456]-parts-check-leaks-p1456.jpg
File Type: pdf
Old Mar 15, 2016 | 11:25 AM
Ttripp's Avatar
Yes i will be checking for Cracked hoses this weekend, once this part comes in.
icanbne1
Nov 9, 2013 02:19 AM
LordAccord
Aug 27, 2012 06:42 PM
muffinman617
May 10, 2011 03:05 AM
DisplacedMic
Dec 2, 2010 03:14 PM
Mott23
May 17, 2010 08:31 AM
