"idle to low!"
I have a problem on my 2000 accord vtec its a v6 but it started to do it by its self whenever i turn it on and off couple times the next time i try start the engine the car turns on but then just turns off i retry to start it but have to hold the gas for a little and stays on but shakes and idles really low just like his does anyone know how fix it?
First, go through this process. It covers the common things.
https://www.hondaaccordforum.com/for...e-speed-38734/ |
Thank you
Hey thanks imma try this and it also has the check engine light my dad's friend put the code reader
And it said misfire in all the cylinders |
Random misfire can be ignition problem. How old are the spark plugs, what brand are they? How about the plug wires, distributor cap? (not sure if it has coil-on-plug yet in 2000?)
Re
The sparks plugs are almost new I changed them right when it started messing up but didn't put NGK so car felt weak so I changed them again all 6 and installed NGK LASER ones and it has coils no distributor
Sounds like heat soak, the v6's in this gen had/have an issue with this due to the design of the the fuel rails/lines.
I'll see if I can find the documents on this, my guess. Lets say you run the car until it is nice and warm....shut it off. Give it 10~15 minutes and when you re-start the car this issue happens? |
