Sponsored by:
Sponsored by:
96Accord Ex Manual trans. Starter will not activate
Old 09-17-2022, 03:54 PM
Drivingmecrazy2's Avatar
Default 96Accord Ex Manual trans. Starter will not activate
Have replaced the starter (2 X), ignition switch, both clutch pedal switches, battery, ground wire. Still will not activate the starter. Runs if compression started.
Old 09-17-2022, 08:56 PM
Verify the small blk/wht wire connected to the starter has 12V when you turn the key to the start position.
On the clutch pedal switch (I believe the lower switch) there should be a grey and black wire. Check that the grey wire has 12V when the key is in the start position.
Chezzie Massey
11-06-2018 03:49 PM
neuhnda
09-23-2014 10:27 AM
steak2286
01-09-2012 07:05 PM
cinobyte
11-16-2011 05:23 AM
brittanym06
08-01-2007 09:58 AM
Quick Reply: 96Accord Ex Manual trans. Starter will not activate
