intake tightening sequence and torque
new to the forum and first post.
good youtube vids gave me the courage to remove the intake on my 02 accord 2.3 4 cylinder to clean of deposits and hopefully fix the PO401 code, The gasket looked plenty good so I didn't replace it--------many of the vid makers say no need to if it comes off cleanly. Now I have it back on and realized none of the numerous vid makes even mentioned bolt tightening sequence and torque which id guess is very important. Can anyone advise on front of the intake a bolt in center with nuts on 2 studs on each ends,,,,,,,,, on the back side are 2 bolts. any insight on the process to reattach this intake is appreciated. |
Originally Posted by yabadabadoo
(Post 383576)
good youtube vids gave me the courage to remove the intake on my 02 accord 2.3 4 cylinder to clean of deposits and hopefully fix the PO401 code, The gasket looked plenty good so I didn't replace it--------many of the vid makers say no need to if it comes off cleanly. Now I have it back on and realized none of the numerous vid makes even mentioned bolt tightening sequence and torque which id guess is very important. Can anyone advise on front of the intake a bolt in center with nuts on 2 studs on each ends,,,,,,,,, on the back side are 2 bolts. any insight on the process to reattach this intake is appreciated. I hope this helps. Edit; start with the center bolt, then pick a rear corner, then go to the other corner (1 of the nuts), then do the other rear corner, then finally the last corner (the other nut). |
don't use old gaskets. you'll soon discover that they leak and have to do the job again.
