It's time to change my Timing Belt on a 95 honda accord v6...
It's time to change my Timing Belt on a 95 honda accord v6...I need
Holder handle 07jab -001020A , holder attachment, 50 mm 07mab -py3010a and Socket, 19mm 07jaa-001020a Can you tell me where I can find these tools otherthan at Honda? tks |
These tools are readily available from ebay, amazon, et al.
If you have access to a powerful air impact, 500+ ft-lbs breakout torque, then you may be able to break loose that way. An acetylene torch to heat the bolt head will also reduce torque to break the bolt loose. good luck |
