Please help trying to help a broke kid
Old 02-13-2015, 01:08 PM
tsawyer123's Avatar
Default Please help trying to help a broke kid
1998 11/97 Accord lx 2.3 auto. So I'm trying to help a high school kid out he has this beater trying to make it last. I replace the rear main seal frt pump seal and axel boots reassembled car and now it wont accelerate meaning no power at all just bogs down in or out of gear ck codes had a stored code for tps replaced it still same no other codes stored it will idle fine as soon as you give it any throttle it will either surge or die I have gone overt every connector I touched nothing is loose or disconnected been doing this a long time but mostly old school cars every now and then it will rev but immediately shuts back down going crazy any ideas never had an issue like this before .
Old 02-13-2015, 01:28 PM
What were the problems before you started the repair?
Old 02-13-2015, 03:44 PM
There are several TPS related trouble codes. What was the specific trouble code number?
It can be as issue with wiring, connection or the PCM if it wasn't due to the TPS.
Old 02-13-2015, 05:18 PM
M-train's Avatar
I did the same thing as you did, and the same thing happened.
You have a connector wired backward on the transmission. Some of these connectors on the Honda's can plug into a wrong connector. [usually most car makers make sure that a connector can ONLY plug into the correct connecter, but Honda for some reason don't do it with the trans connectors].
Also, you just might have the shifter lever at the transmission adjusted just a bit off.
Old 02-13-2015, 06:59 PM
What are the colors of the three wires going to the TPS?
If the car was fine before. Then during the work you removed the connectors from the TPS and MAP sensor....then after the initial work this new issue showed up.....It is possible to switch the MAP and TPS connectors on 5th AND 6th gen 4 cyl Accords. If this happens, the car will act almost exactly as your description. Just my two cents and costs you nothing but telling us the color or the wires going to the TPS or MAP
Old 02-13-2015, 07:07 PM
Also, the TPS connector is blue, while the MAP sensor connector is gray.
Old 02-13-2015, 08:00 PM
^ I forgot about that...Thanks for reminding me
Old 02-13-2015, 08:50 PM
Lol, we both see this same issue a bunch of times on this forum and the "other" forum.
razingkane
03-02-2014 12:58 PM
93Accord2.2
08-18-2013 04:30 PM
nervousmom
01-03-2013 07:32 PM
g22cd5
11-05-2010 01:29 AM
drugrep
06-29-2010 02:59 PM
Quick Reply: Please help trying to help a broke kid
