Key-less Entry Problem
Hi all,
My key-less entry to my 2006 Honda Accord is working sporadically, any ideas what could be causing that? I click the unlock button on the key and the doors do not unlock. Wait about 10 seconds, start clicking again and the doors do unlock. I know it is not the key as I replaced the battery and can tell the key is sending a signal, also tried my other key with the same result. Thanks in advance. |
Possibly a problem with the driver's master switch. The receiver antenna for the keyless system is located in the power window master switch (door multiplex control unit).
Thank you redbull,
Would you suggest I replace the driver's master switch? Or the multiplex control unit? |
The driver's door multiplex control unit is part of the driver's master switch.
