knocking noise on front left side of car when turning
whenever i turn, there is a loud knocking noise on the left front side of my 95 accord. any ideas on what this could be?
Hi Member
1 Attachment(s)
Please...use the search engine here in the forum..that question has been answered
at leat 50 times in the last year.. A lot of questions can be found answered in the search forum above.. Please use it folks..saves you alot of time typing... WheelBrokerAng :) |
I know this: CV joint, front wheel bearing assembly. Pretty common. I had to have mine done, I have a 95. The front bearing assembly/brake rotors don't just fall off, you have to have a slide hammer, impact tools. I took mine to a shop and $$$$. Usually "shadetree mechanics" will just pound them off with a big hammer. Not good.
Just the CV joint.
CV & axle seals!
DO NOT replace any parts till properly diagnosed, if it does turn out that you need a new axle , you DO NOT need to replace the axle seal unless it is leaking now ...
sounds like a bad outer cv joint to me .. |
Look at the joints and see which boot is torn and that is usually the bad one. I have not liked the aftermarket rebuilt axles I have installed. They always seem to be a pain to get to seat properly in the trans without work on the retaining clip or cleaning up the spline. At one time people would just replace the joint with a new one, but I think it was more money than a rebuilt axle. I also remember some of Honda’s axle doesn’t come apart to easy or at all. Let us know what you find.
