-   -   Leaking (https://www.hondaaccordforum.com/forum/general-tech-help-7/leaking-64225/)
Moochdog Jan 18, 2017 08:28 PM
Leaking
Well guys I have a 2002 Accord and I rebuilt my transmission myself. I had a hard shifting problem due to a sluggish pressure solenoid but I have replaced that. The problem I have now is that is leaking from the shift solenoid with the brown connector I forgot what it's called but I replaced it twice and it's still leaking the is no hard shifts but just a delay when cold going in the gear but when warm no problem it's just I don't like it leaking I would hate to have rebuild it again cause of the leak
JimBlake Jan 19, 2017 07:56 AM
Is it leaking through the solenoid or around the gasket for that solenoid? Those would be easy without doing anything else to the transmission. New solenoid or maybe only new gaskets & pay attention to the surfaces where the gasket seals against.
Moochdog Jan 19, 2017 02:53 PM
It seems to be leaking around the solenoid the surface seems smooth like it's pose to but when I had it in a transmission shop having it installed he looked at it he couldn't figure out why n I don't want to keep filled it up it's a waist of money
Moochdog Jan 19, 2017 03:17 PM
PAhonda Jan 19, 2017 05:51 PM
Did you replace the solenoid, or the gasket twice?
Moochdog Jan 21, 2017 06:22 AM
Well guy I think I found it I was a pressure tap bolt for the valve body that wasn't tight I guess it was from the transmission place I never touched it
