'91 steering pump removal?
remove the 2 10mm bolts that hold the p/s pressure hose in place, move hose out of the way,, keep the hole upward position or p/s fluid will come out,, once hose is out of the way remove the 2 remaining bolts that hole the pump in place, also remove the soft hose held in place by a clamp .keep the hose upward as well or p/s fluid will come out .
Piece of cake.. :-)
Piece of cake.. :-)
I have a 93 Accord and yeah remove the PS pump, I changed my alternator without removing the pump and it was a pain in the butt. Today I pulled the pump off to change the seals and I wish I would have known it was this easy when I changed my alternator because it would have saved me a ton of time and a lot of headache. Yeah I just tied up my hose's to keep them up out of the way and to keep fluid from leaking out. Don't worry it's a piece of cake.
creator1322
12-06-2010 03:40 AM
