Location of lock/unlock wires
I searched around, but I was not able to find the lock and unlock wires on my 97 accord.I know the lock in black/white and unlock is orange,but don't know where in the kick panel they are located. Any help with pointers on where to look or a pic would be great. Thanks.
RE: Location of lock/unlock wires
On my 91 the keyless system is wired to the door lock switch in the drivers door, the wires are fairly easy to access. This is the case with most cars with a power door lock switch.
Yes I know I can access them there, but do you know where in the kick panel they are located because I need to tap into it there only.
Hmm, well if you already know the color it should be easy to find it in the harness that comes in from the door. I believe this wire comes in right above the fusebox in my car, pretty easy to get to but it may be a PAIN to wire something to as most cars don't leave a lot of slack in the harnesses.
