Misfire on different cylinders
I have 2008 honda accord v6 exl vtech engine light blinking and vsa light comes on dealership will change spark plugs first time #3 when cyl 3 & 6 misfire, 2 wks later happened again cylinger 2 they changed 1 & 2 spark plug. Researching problem no answer for cause tech line was replacing main seal but said that cylinders was still misfiring. I am close to warranty end and have parked my car any suggestions thanks
Reading car complaints on the 2008 Accord, people mention the spark plugs failing including porcelain losses.
have dealer fix it,,,,,,,,,it is under warranty ,, as long as you have an issue while under warranty ,,even if you go over the warranty and same issue is still there dealer should do it still under warranty ( assuming you don't go back 1 year later or thousands of miles later )
stay on top of dealer till they fix it .. |
