Is my Catalytic Converter bad???
Hey guys. I'm new here driving a 93 honda accord se. It's an automatic. I'm having issues some weird issues. Everytime I start up the car, lots of white smoke comes out but after driving a while, it goes away. I do notice that it sometimes have trouble accelerating on cold starts but it goes away once it heats up. The car does not over heat in any kind. No check engine lights. I'm not losing any coolant. I'm curious because I took the car for a California Smog Check and it failed the 15 mph run. It pass the the 25 mph run. ??? The smog owner says it could either be the oil, catalytic converter or the engine. I've checked the oil and its fine. I'm hoping it's not the catalytic converter and if it was it, can someone tell me how I will know? I don't want to replace it and find out it wasn't. That converter cost $$$. The smoke looks whitish and it does blow alot out. The smell also stinks a little. What can it be??? HELP! :(
If the smoke is bluish-gray, it's oil smoke. A pure white smoke is almost always engine coolant from a head gasket leak. However you should be losing coolant if it's pure white smoke (steam).
Did you fail the NoX level? If yes and no Check Engine Light, the EGR ports/manifold is likely blocked and needs cleaning. Check youtube for a video "PO401 EGR Valve Port Cleaning" which shows the process on a later model. Relatively easy job. Honda catalytic converters are good and rarely fail so look hard elsewhere before replacing converter. good luck |
(Post 220631)
There are really only two liquids that can easily get into combustion chamber; oil or engine coolant. Small possibility of brake fluid through the vacuum booster and master cylinder seals.
Coolant smoke is bright white and has a sweet chemical smell, while oil is grey-blue, oil smell. good luck |
I've checked my engine oil today and notice tiny little bubbles on my oil dipstick. There are several tiny bubbles in the oil. I've done some research and I got 2 reasons.... It could be bad oil addictive or water leakage from either a cracked block or blown headgasket. My engine isn't overheating at all. I still have coolant and it is not leaking no where. It's still on FULL mark and I've checked the radiator. It's all still fine and full. I'm probably going to change the oil again to 5w-40. Hopefully, after this, no more white smoke from start up and no more tiny bubbles..... If worst comes to worst...... RIP F22A6..... and maybe H22.....
Is it beginning to get cold where you live? Park outside overnight? Condensation (moisture) in the crankcase isn't very unusual from that situation. If you only ever drive a couple miles then it never has a chance to get hot & dry out.
If those little bubbles are actually anti-freeze, then you got a problem with the headgasket or block like you said. I'd probably stick with 5w-30 especially if it's getting colder. |
Originally Posted by JimBlake
(Post 220816)
