Need ABS module pump
Need new ABS module for 2013 accord ex-l 4c. I'm not sure what the part number is on the unit itself. Trying to get a used part and not having luck without the correct number. I found a few numbers on the original unit, but not sure which one is the correct one. Any thoughts where the correct number is on the unit?
Thanks
Thanks
I'm pretty sure the abs pump is part of the abs module. The 2013 accords probably call it the VSA module.
To find an OEM part number, go to a site like hondapartsnow.com, enter your vehicle info, then you will find the OEM part for your car.
jhk1976
Aug 17, 2007 04:39 PM
pturnbul
May 3, 2007 02:30 PM
