need help!!!
rpm gauge not working. '91 honda accord ex manual. any help will do. thaxz
RE: need help!!!
You can remove the cluster and replace the Tach as a separate part, salvage yard might be the way to go.
RE: need help!!!
wire just might be loose at the distributor. its the blue wire
RE: need help!!!
hook up a external tach... if it reads "0" then your problem is with the pickup for the tach
RE: need help!!!
ORIGINAL: hondadude You can remove the cluster and replace the Tach as a separate part, salvage yard might be the way to go. heck it could be a loose connection at the ignitor ( blue wire) i have seen it before |
