Need help with removing an actuator
I've got a 2004 Accord EX-L coupe and I've gotten to the actually assembly however I can't seem to remove it. I have removed one latch however there is a brass rod from the handle going to the assembly holding it in there denying me access. I am at a loss what to do because I can't seem to find enough information online as to how to actually get it off so any help would be greatly appreciated.
I'm sorry I meant for the driver side door it was for the locking mechanism
Just to get a better understanding here is what I'm looking at. I've sucessfully removed the smaller silver rod however the one keeping the whole thing in there is the brass/golden looking one and there doesn't seem any way to remove it from the handle.
Shop manual indicates the part should come out w/ latch assy. Rod is the outer handle rod and likely must be disconnected at outer handle. Same for the door manual lock cable (gray cable at bottom I think).
A shop manual may be helpful. You can download one from automanualsource.com for $22.
