Need replacement connector for Denso heater blower
'97 Accord. My heater blower has been quitting intermittently and I discovered that the two-wire (yellow/black stripe and blue/red stripe) connector that plugs into it has melted, causing a poor connection. I've replaced the motor but need to find a replacement connector, hopefully with a pigtail. Can anybody tell me a source where I can find one?
Best bet is to find a u-pull-it junkyard and cut off the connector and a length of the wires to splice into your blower motor. I also saw one on ebay.
I'm not sure if you can find the connector from the dealer or oem sites like hondapartsnow.com. 04321-SM4-405 looks like the blower connector, but you would have to look at the matching connector on the hondapartsnow.com diagram (looks like it is for the bulb on the front bumper). Maybe it is a match? You may have to pull the new blower motor to see if it is actually the same connector. |
Ebay has the used pigtail connector:
ebay.com/itm/143580141271 |
