Need urgent help!!
My car is a 2002 with >205k miles on it. For the most part it's still running very well but it's starting to act funny. It idles low which shakes the engine which thereby shakes the car. Mind you, the shakes aren't like tremors or anything but with them being associated with the low idle I'm concerned. I was originally thinking it might be either bad gas or the idle control valve. I'm not sure though. Any suggestions?
Sorry, don't think I can really help with your problem, but welcome to the site! I would google around if I were you and see if there's anyone else with similar problems. :)
Set your base idle. There's a thread in the DIY section about that.
Is it 4-cyl? V-6? Automatic trans? |
Hello New One..Welcome..as you can see..HELP goes in the help threads..
WheelBrokerAng :) |
Originally Posted by JimBlake
(Post 277895)
When were the spark plugs last changed? Did you use the NGK plugs recommended by honda?
Does your 02 have a distributor, or is it a coil-over-plug setup? |
| All times are GMT -5. The time now is 04:07 AM. |
