2002 accord ex 2.3l keyless entry help
I have a 2002 honda accord ex 2.3l 4 door. "I" lost the remote for the keyless entry system. I got a replacement tryed to program, with out any luck. I took the car to the local dealer to have them program it (in case I wasn't doing the programming correctly), again it would not program.
I wen't to the parts department and barrowed a brand new one to see if it was a bad remote, but with the same results.
So I need some help finding the receiver, trouble shooting, and looking into the car itself (maybe a fuse?). I have some fixing abilities, I just don't want to dig for a problem under the dash if it is in the trunk...
Is this the procedure that you tried? It has worked for my former 1998 and 2003 Accords.
programming remotes...
1) Unlock Doors
2) Turn ignition key to "ON" position (II)
3) Press the "LOCK" or "UNLOCK" button on the remote
4) Turn the ignition key to the "OFF" position (0, I)
5) Turn the ignition key to the "ON" position
6) Press lock or unlock
7) Turn key to off position
8) on position
9) lock or unlock
10) off position
11) on position
12)lock or unlock - doors should cycle to indicate successful programming. If you only have one remote, turn ignition to off or don't touch anything. if you have 2+ remotes, go to 13:
13) lock on each transmitter that you need to program
*Steps 2-12 must be performed within 5 seconds of each other. Step 13 can be performed within 10 seconds of step 12.
This belongs in General.Tech so I'll move it.
1) Unlock Doors
8) on position
9) lock or unlock
10) off position
11) on position
kalebjohns
09-16-2014 01:45 AM
daanish_b
08-08-2013 01:31 PM
